Need Lift Pump for Case 1194 / DB 885
WillE
05-11-2004 10:28:14
Anybody know where I can get a used lift pump for a Case 1194? I had a snap ring break in my PTO housing. This let a gear slide forward and warp the shaft of the drive gear in my pump. It makes it so that the outer gear that meshes with the PTO gear sits out to one side and doesn't contact the PTO gear. The pump is fine other than the one bent shaft. Anybody got a core they want to sell? I know a new pump is around $400 and I'd like to get away without buying a new one. Thanks for the help. Anybody that knows of a good Case/DB salvage yard please share. These things are really scarce here in the south east US. Thanks again.
WillE
05-11-2004 11:26:44
 Re: Need Lift Pump for Case 1194 / DB 885 in reply to WillE, 05-11-2004 10:28:14
I said lift pump. I meant hydraulic pump. Sorry for the error.
kyhayman
05-11-2004 10:57:40
Lift pump (not injector pump) was 54.95 new from Case last fall. Used parts, I get almost all my Case DB parts from Pleasent Hill Salvage, Pleasureville, KY 502-845-4467, literally acres of them.
