Lighting Problem - Bad Ground
John L.
05-10-2004 20:03:19
So I've created a monster. Now that dad's VAC is running again, and since I rewired most of the tractor, he wanted me to tackle the rear light that hasn't lit in at least 10 years. Turned out that the light wasn't getting a good ground. Instead of 6V I had about 1V getting to the light. Replaced the hot lead and had the same problem. I couldn't figure out where the seat had become insulated, so I ended up running a new wire from the mounting bracket of the light to a bolt connecting the seat frame to the diamond plate. That was the first place I could measure more than 1V between it and the hot lead. The light works.
Now my question. Was this third rear facing headlight standard on the VAC? I don't recall seeing the back end of a VAC in any photos other than shots of the PTO, Eagle Hitch, and drawbar. There has been so much other work done to the tractor (the angle iron frame for the snow blade and the cream paint job and new decals for example) that I just don't know what is and what isn't original.
The light mounts to a small "L" shaped peice of steel that looks stock, and that mounts just under the seat. No other switch for this light either, when the lights are on all three are on. There is a small "guide" to the left of the shifter for the wire to pass through so I always thought it was stock. However, something about it after working on it makes me think otherwise.
The good news is after all the work on the electrical and carb the tractor runs great. Seems a lot smoother to drive now than it used to be.
C. Amick
05-11-2004 09:43:18
 Re: Lighting Problem - Bad Ground in reply to John L., 05-10-2004 20:03:19
My dad's 1948 model has a light mounted to the bottom of the seat as you described and I'm pretty sure it is original.
Brandon
05-10-2004 21:39:27
Your taillight description sounds exactly like the light for our '49 VAC.
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
John L.
05-10-2004 22:47:50
 Re: Re: Lighting Problem - Bad Ground in reply to Brandon, 05-10-2004 21:39:27
Thanks Brandon!
