SC heads
Mike Schwartz
05-10-2004 19:47:01
Hello, I have located two parts engines for a case SC project tractor. I see that one of the heads has a casting number 5618A, the other has a number 5617A. Is the 5617A a higher compression head? This engine was a power unit on a V case combine, 1945 I think. My '42 SC has a two fuel manifold and both tanks and the '49 SC has the gas manifold and only one tank, both have the head casting 5618A. Does anyone know if any other parts from power unit engine are different than the tractor engine parts? Thanks, Mike (WA)
C. Amick
05-11-2004 09:55:38
 Re: SC heads in reply to Mike Schwartz, 05-10-2004 19:47:01
I am told that head numbers ending in "18" are low compression and numbers ending in "17" are high compression. I have a 1945 SC that is dual fuel. I start it on gasoline with the shutters closed and switch it over to kerosene when the engine temperature reaches 180 degrees. I find that it runs much smoother on the kerosene and seems to use less fuel, but has less horsepower.
