what kind of hyd oil in 530 CK?
Duke in Tucson
05-10-2004 12:44:10
I had a couple of small leaks, (loose things)so I put some Coastal tractor fluid in and now its coming out all over the place! What weight do I need,or should I add stop leak/conditioner? Duke
Dennis/Ohio
05-14-2004 03:20:55
 Re: what kind of hyd oil in 530 CK? in reply to Duke in Tucson, 05-10-2004 12:44:10
Hi Duke,
I buy from a local oil dealer to save a buck. They said many customers buy 15 weight hydraulic oil for machines with leaks. The actual Case TCH fluid is a multi-viscosity oil (5w-15 I think). I was using 15, now I'm using 10 weight but if I get all the leaks and control valve internal leakage corrected. I'll try a multi-vis. I let the 10 weight warm-up good before I use The loader or hoe.
Best wishes, Dennis.....
