Case 310B Front Axle
Scott Flynn
05-10-2004 11:03:47
Anyone have information on how to properly remove/disassemble the front axle and spindles for this tractor? It has the heavy duty wide front end. One of the spindles snapped on mine and I've sent for a used replacement. However, it's not clear to me how to properly remove the spindles. In addition, I'm going to put a new pivot pin in the axle and rebuild the power steering cylinder. Any information on these processes will be appreciated! Thanks.
Mike Johnston
05-11-2004 06:42:55
 Re: Case 310B Front Axle in reply to Scott Flynn, 05-10-2004 11:03:47
third party image
This is a 200, but they are close enough for comparison. The axle, A-frame and mounting brackets drop very easily. I removed mine to get the pan off. Have not tried to remove a spindle.
The power steering cylinder can be improved with just a few O-rings. I only did the valve on mine, but the shaft & cylinder can be refreshed also. If you need a parts drawing of the cylinder or axle, let me know & I'll post it.
Mike Johnston
Scott Flynn
05-11-2004 19:20:49
 Re: Re: Case 310B Front Axle in reply to Mike Johnston, 05-11-2004 06:42:55
Looks just like it. I am trying to figure how to remove the king pins without damaging the plugs at the top and bottom. The plugs are no longer available from Case. I'm also considering removing the oil pan to put a new gasket on it.
