SC engine temp
John McMillian
05-10-2004 10:38:43
My '51 SC engine temperature runs a steady 140 F. There is no thermostat, that I am aware of. Should I have a thermostat to raise the engine temp to 185F ? I understand that gasoline engines run better at that temperature. Comments?
C. Amick
05-11-2004 10:12:45
 Re: SC engine temp in reply to John McMillian, 05-10-2004 10:38:43
I read somewhere that maximum horsepower is achieved around 180 degrees. I think if it runs too cold you get more engine wear.
todd hamilton
05-10-2004 19:45:29
My SC doesn't have a thermostat either, but should get one installed. I don't use my tractor very much in hot weather but the restriction of the thermostat will help the radiator function better - gives the water time to cool before returning to the engine. I get optium performance at 180 degrees but over 200 (I was pulling bushes in hot weather) it will boil over and run out of the overflow. Mike's 160 is probably the best recommendation.
george md
05-10-2004 20:43:46
 Re: Re: SC engine temp in reply to todd hamilton, 05-10-2004 19:45:29
Todd,
Earlier this evening I sent Mike a chart out of my DC book of operating temperature versus engine wear . maybe he will post it , if not give me a email and I'll send it .
george
John McMillian
05-11-2004 05:13:43
 Re: Re: Re: SC engine temp in reply to george md, 05-10-2004 20:43:46
Thanks, could you send me that chart?
george md
05-11-2004 14:00:43
 Re: Re: Re: Re: SC engine temp in reply to John McMillian, 05-11-2004 05:13:43
John,
Be glad to send a copy , but need an addy.
george
Mike Schotte
05-10-2004 11:45:11
I've got a 160 degree thermostat in my SC. I bought a 140 degree T-stat, but didn't install it after reading some of the archive posts.
-S.
John McMillian
05-11-2004 05:14:41
 Re: Re: SC engine temp in reply to Mike Schotte, 05-10-2004 11:45:11
Where does the thermostat install at? Is a standard automobile type?
Bob KY
05-11-2004 05:44:58
 Re: Re: Re: SC engine temp in reply to John McMillian, 05-11-2004 05:14:41
The thermostat goes in the upper radiator hose just above the outlet on the cylinder head. Yes, a regular car/truck thermostat will work, but you will probably have to trim a little off the edges with some tin snips to get it to fit snugly in the rad hose. When you install it, be sure that it doesn't turn sideways on you when you slip the rad hose onto the head outlet. I used a hose clamp around the rad hose to keep it in place.
Also, you should drill one or two 1/4" holes in the thermostat to let any air pass through and to allow a small amount of circulation.
