Vac-14 Brakes
Slowpoke
05-09-2004 22:59:16
The seals on the bearing carrier have leaked and oil has caused complete loss of brakes. Can someone tell me the Chicago Rawhide or National seal number to replace VT5095/A29518? The numbers do not show up in C-R catalog. This is the regular brake shoe version. The tractor is 120 miles away and I didn't have the time (Mother's Day) or the tools to pull the seals. I also need to know what size socket to use for the large nut that holds the drum. Thanks
Joe (Wa)
05-10-2004 08:27:20
 Re: Vac-14 Brakes in reply to Slowpoke, 05-09-2004 22:59:16
My parts manual shows VT5095 as the nut, I do not know the wrench size.
Same parts manual shows seal is VT3465. That Case number crosses to National 450316 at the link below.
Joe
Link doesn't appear to be posting? Copy & paste:
http://12.105.77.22/cgi-bin/search.pl
Slowpoke
05-10-2004 09:22:56
 Re: Re: Vac-14 Brakes in reply to Joe (Wa), 05-10-2004 08:27:20
Thanks, Joe. I posted the nut number instead of the seal number. The correct numbers are Case VT3465 or A30501. A parts person/mechanic has written in lots of new Case "A" numbers in my book.
Now either number shows up in the C-R catalog as CR22446.
Joe (Wa)
05-10-2004 10:21:07
 Re: Re: Re: Vac-14 Brakes in reply to Slowpoke, 05-10-2004 09:22:56
Slowpoke, Thanks for the "a" number. I wish I had your parts manual.
Do you cross-ref to CR numbers on-line? If so I would like to have a link.
Joe
Slowpoke
05-10-2004 18:25:21
 Re: Re: Re: Re: Vac-14 Brakes in reply to Joe (Wa), 05-10-2004 10:21:07
Joe, I don't know how to make links but at the CR site just put in the search box the seal number from the VAC parts book (or any other manufacturer's number) and it will show the CR number. The old "V" and new "A" numbers both gave the same CR seal. Of course, they won't tell you a National number, you tell them and they'll give the CR number. Put "Chicago Rawhide Catalog" in a Google search box. Click on "click here" on the CR site page. That will give you the CR search box.
I ordered two of the VT3465/CR22446/National450316 seals from my auto supply at $11.88 each.
Slowpoke
05-10-2004 18:23:14
I ordered two of the VT3465/CR22446 seals from my auto supply at $11.88 each.
Joe (Wa)
05-10-2004 20:05:56
 Re: Re: Re: Re: Re: Vac-14 Brakes in reply to Slowpoke, 05-10-2004 18:23:14
Thanks Slowpoke, Have fun changing your shaft seals. Joe
