Another diesel filter question.
Kirk-Tx
05-09-2004 19:50:38
My 830 diesel would crank immediately when I would hit the key when I bought it. I took it apart including draining and removing the diesel tank. After painting it, I changed the three filters. Followed the instructions on bleeding the air out(10-15 times). Now I have to grind the starter for a long time to crank. I have pulled a shreader for a couple of hours and have plenty of power and it runs great. Why will it not crank easily like before??
Kirk-Tx
05-10-2004 14:54:57
 Re: Another diesel filter question. in reply to Kirk-Tx, 05-09-2004 19:50:38
I will try to link my pics so you can see my project. Have not got the after pictures posted yet.
Kirk-Tx
05-10-2004 12:17:21
I took diesel tank off with all of the sheet metal to sandblast and paint. While I had the diesel system open, I decided to change filters since I had no history on when they had been changed. Since painting it, I have noticed a few small leeks of something that dust is collecting on. Could be I need to check some connections. I checked the last filter and it was all tight. Thanks for the help.
Doug TX
05-09-2004 22:45:20
What all did you take apart, and why?
Steve G
05-10-2004 05:05:57
 Re: Re: Another diesel filter question. in reply to Doug TX, 05-09-2004 22:45:20
Sounds like you are sucking air in when it sits. Are you sure that your lines for the filters are tight and the seals good. Also are your bleed screws not leaking. The upper canister filter under the hold could also be the problem in that the bleed screw is leaking or the check valve that is located in it allowing the fuel to bleed back. Just some thoughts.
