eagle claw hitch
ray
05-09-2004 18:32:08
can I cut off eagel claws and weld normal end on it. thank you ray
case poor in pa
05-11-2004 18:43:17
 Re: eagle claw hitch in reply to ray, 05-09-2004 18:32:08
i dont know why youd want to cut them off. but ill buys the claws off ya..
mj
05-09-2004 21:47:52
third party image
Here's one where a guy modified the rigid arms so that they will swing (the double-nutted bolt is the pivot) or can be pinned (thru the holes shown towards rear of double-nutted bolt) so that they are rigid side-to-side. He used some 1/2" strap and the original axle mounts. This was originally one of the factory add-on Eagle Hitches for the high pressure system and it came with the ball-type ends but would work on the later low-pressure Eagle Hitch tractors as well. I've got one with the later hitch and the 'claw-type' mounts and sometimes I have to loosen the axle-clamp bolts and spread the arms a little to hook up to some of the odd-ball implements that I have around here.
Glenn FitzGerald
05-09-2004 18:43:03
Eagle hitch arms are rigid. How would you hook on implements if the arms cannot move side to side?
jdemaris
05-09-2004 18:53:17
 Re: Re: eagle claw hitch in reply to Glenn FitzGerald, 05-09-2004 18:43:03
I've got three tractors that have Eagle hitches - and they're all wore enough that they have enough swing in them to hook stuff without opening the claws. But . . . I don't understand what there is to gain by converting them? I like them. I've got pull-wires tied to mine, and quite often I can just back to an implement, pull the wires, open the claws, and get hitched without getting off the tractor.
