DC Horsepower
Barry's DC4
05-09-2004 18:24:03
Hey pullers - what HP would you expect from a good running DC with 4 1/16" M&W flattops, 5505 heads, AC Delco ignition w/ hot coil, and re-jetted carb (everything else stock). I'm finishing my DC-4 resto/rebuild, just want to know what to expect. Thanks for the help.
bill wilson
05-11-2004 19:22:36
 Re: DC Horsepower in reply to Barry's DC4, 05-09-2004 18:24:03
Motec does my carbs and did one for me for CC puller You cannot get a better carb than his Where are you guys located, I am from Ind but retired in montana
Dave S
05-12-2004 11:45:15
 Re: Re: DC Horsepower in reply to bill wilson, 05-11-2004 19:22:36
Bill, located in Albany,WI. I got a set of sleeve o-rings from you late winter. Dave Schupbach
Dave S
05-10-2004 10:56:58
Barry, also have zenith carb built by Motec if your interested. Dave
CJ
05-10-2004 15:25:04
 Re: Re: DC Horsepower in reply to Dave S, 05-10-2004 10:56:58
Dave I would be interisted in the carb how much and what was done to it?
Dave S
05-11-2004 00:59:00
 Re: Re: Re: DC Horsepower in reply to CJ, 05-10-2004 15:25:04
CJ, Carb was done by Motec, bowel reworked, larger jetting, larger venturi. You can really move the the gas through it. I also had a M/S redone and put that on my DC. Choke has also been removed which kind of makes it a pain to start when its cold out. $200 plus shipping. e-mail me at [email protected]
Dave S
05-09-2004 19:49:52
Barry, my DC has 47 hp with 4" stock flat tops, delco dist with electronic ignition and hot coil, 5505 head w/ 70 thous removed and carb reworked by Motec Enginerring for pulling. We ran this tractor on the dyno for 2 and 1/2 hours to break it in. Peak hp was 65 but fell flat in short order. Our first pull is saturday the 15th. We'll be pulling farm stock.
