New LA owner questions
Stu Lenzke
05-08-2004 22:54:12
I just purchased a '49 LA with a Dual 300 loader and new 18.4x30s, starter and battery for $800. Runs great, drove home 17.5 miles. Justin will be used year around for snow/dirt work from @-30 to +100. (1)Can I run synthetic 10w30 in him? (2)A friend is scrapping 2 newer LAs, can I replace my master cyl. brakes with the mechanical type? Is it a bolt on mod? (3)Has anyone mounted a block heater on an LA? (4) What should I use for modern differential lube? (5)Has anyone ever tried making a crankcase dipstick using one of the access covers? (6) Has anybody mounted paper type air filters? (7) How hard is it to mount the rear cover hyd. pump on an LA? one of the scrappers has one on it. Thanks for any help.
mike's600
05-09-2004 05:13:36
 Re: New LA owner questions in reply to Stu Lenzke, 05-08-2004 22:54:12
I would get the new LA's for parts first, it would be simple just to install your good engine into the LA with diff brakes.The hydro out of a 500 case may work in the back of your LA, may need to check a parts book for interchange.The factory lubrication in the engine and trans should be fine in your area.I need to look at my La, can't remember how much rubber rad hose there is, may be enough to get a after market heater installed.
mike's600
05-09-2004 05:16:21
 Re: Re: New LA owner questions in reply to mike's600, 05-09-2004 05:13:36
I don't think there is an advantage adding a paper element filter over the stock set-up if you are just working the tractor.
John Saeli
05-09-2004 05:04:14
Hey Stu: I would be concerned that the 10W30 would be too thin. I've had vrey good results with 15W40 year round. For the differental I'd use 85W140 Gear oil. When cold you have the flowability of an 85, and when hot, the protection of a 140 oil.
Bob
05-09-2004 12:28:25
 Re: Re: New LA owner questions in reply to John Saeli, 05-09-2004 05:04:14
One of my LAs has a dip stick tube (and dipstick) brazed into one of the inspection plates. It works fine, but no great advantage over the oil level holes and plugs.
Stu Lenzke
05-11-2004 08:48:01
 Re: Re: Re: New LA owner questions in reply to Bob, 05-09-2004 12:28:25
Gentlemen, thanks for all your help, I'll be trying the 15w40 oil, and the 85w140. I'm afraid the swap engines suggestion is not an option, but pillaging is, and I plan on grabbing guages, a radiator, the brakes, a hood, rr fender, all the lights, a gas tank, generator mounts and a carb & head at least, I also have a dead '48 LA that Justin will serve as a running example to repair. Thanks again, Stu Lenzke
Stu Lenzke
05-11-2004 08:45:14
