Have would this ring gear fit on 134 tooth flywhee
Nicholaus Sowde
05-08-2004 16:34:19
Have would this ring gear fit on 134 tooth flywheel ring gear? It is supposed to fit on a case tractor. Thanks
maybe this is what you ne
05-09-2004 13:39:02
 Re: Have would this ring gear fit on 134 tooth fly in reply to Nicholaus Sowder, 05-08-2004 16:34:19
better make sure you check if the starter gears will mesh in first. then heat up ring gear and put it on flywheel let cool then vroom vroom..
