case tractor brakes
ray
05-07-2004 19:15:23
I just bought a case tractor to fix up. It does not have any brakes. also has wierd 3 point hitch, someone put a car rotor on front with car wheel on it. tractor seem strong, how do I adjust brakes. thanks ray
mike's600
05-08-2004 05:07:32
 Re: case tractor brakes in reply to ray, 05-07-2004 19:15:23
The dics in the brake set up are glazed. You may be able to rough them up and re-install. I use a belt sander with 60 grit.You also need to rough up the metal side of the brake cover and transmission housing.If this dosn't work good enough ,buy some new disc.(exspensive)
bean potty
05-07-2004 22:50:00
huh? wud he say??
Dug G.
05-07-2004 20:25:48
what??? I assume you mean your brakes are worj out. See if you can find a serial number on the dash, o engine, so we know what model to deal with. If you can' find it, look thru the photo gallery on th eleft side of this site and try to match it up.
