What is a VAC?
Allen
05-07-2004 09:39:12
Hello,
I usually mess around with other color tractors but have recently run acroos a VAC Case with a broken crank and cracked block for a good price. Can you tell me about the VAC? What is the weight, HP, CID, etc? What does it compare to in a Farmall or a JD? Any help would be appreciated.
Thanks,
Allen
C. Amick
05-07-2004 10:12:44
 Re: What is a VAC? in reply to Allen, 05-07-2004 09:39:12
It's a VA Series tractor with cultivation "C" capabilities. I think the engine is 123 cid. About the same HP as a Farmall C. I have a VAC and 2- Farmall C's. The Case is tougher and more durable. I've been running the VAC since 1969.
Allen
05-08-2004 03:11:37
 Re: Re: What is a VAC? in reply to C. Amick, 05-07-2004 10:12:44
Thanks for your help. I might go get it next weekend.
