Mini Mec Spill Port Timing
Gerard DeVito
05-05-2004 18:17:07
I have a 1982 Case 1690 tractor. I had to remove the injection pump to have it recalibrated. Unfortunatly the engine was rotated after I removed the pump. Since the idler gear meshes between the pump and the cam gear the timing marks cannot be referenced. I am trying to avoid removing the front timing cover and would like to make sure I have proper pump timing. I can get the engine to TDC and I thought if I could set the proper spill port timing on the pump I could set the pump to TDC. I know the injection timing is 25 Deg BTDC. Does anyone know the proper procedure for spill port timing?
dale armstrong
05-09-2004 09:37:50
 Re: Mini Mec Spill Port Timing in reply to Gerard DeVito, 05-05-2004 18:17:07
Gearld, I don't have any idea, but I am in the same way with a David Brown 1200 slectematic, so if you find the answer would you Please pass it along. If i learn any thing I'll do the same.
Thanks
rustytractor
05-06-2004 09:35:05
Maybe you could fix it with a bobber spring or would you have to be crazy to do that?
