DC case
JMc
07-20-1999 17:29:05
does anyone know the approx weight of a dc case thank you
kevin lindley
07-25-1999 16:18:05
 Re: DC case in reply to JMc, 07-20-1999 17:29:05
the approximate weight for a dc depends on the rear tire size. 11-38 rear tires with dual front wheels weigh 4600 lbs. even. with 12-38 tires, its 4650 lbs. with the adjustable front axle, 4300 lbs. and 4350 depending on those tires. with the single front wheel, 4200 and 4250 depending on the size again. for a dcfor tis 4450 and 4500 depending on those two tire sizes. this is straight out of a 1952 case dc original book with live pto and and eagle hitch. contact me if you have a question.
Rich
07-24-1999 14:05:48
third party image
The scan is from the owner's manual
R.M. in Ont.
07-20-1999 17:52:35
They weigh 5300 lbs and up. Wheel weights and
fluid in tires can run them up to 6500 lbs.
