Help, Throttle Sticking ?
Jeff From WI
05-05-2004 13:53:10
I have a 1969 Case 960 Combine, I went to move it yesterday & the throttle is sticking? It's either Full Throttle or Idle??? How can I adjust or Lube? Worked fine last fall. Thanks Jeff
Jeff From WI.
05-06-2004 17:56:31
 Re: Help, Throttle Sticking ? in reply to Jeff From WI, 05-05-2004 13:53:10
Thanks John. I Lubed everything and I Checked the gov for oil, I unscrewed a bolt on top of gov and looked inside. there seems to be no oil??? What kind of oil do I use and how much? Thanks Jeff
John SAeli
05-08-2004 04:41:25
 Re: Re: Help, Throttle Sticking ? in reply to Jeff From WI., 05-06-2004 17:56:31
Hey Jeff: Is there a little oil fill on the back of the governor with a spring loaded cap? About a 1/3 of the way up from the bottom. I'd use some thin oil like a SAE 10. 10-30 would be fine.
John Saeli
05-06-2004 06:16:11
Hey Jeff: 1st, I'd check all the throttle linkage, to & from the governor. Spray some pentetrating oil on all the joints to make sure they are free. Check to see that the governor has oil in it. Hope this helps.
