Case Model L #302894
Karen Nelson
05-05-2004 09:54:06
I have an old Case Model L tractor of my husbands that is partially restored. I cannot determine the year it was made from the serial #. I would appreciate any other information on it. It has rubber tires but may not have had originally. Thanks
Russ
05-06-2004 17:52:32
 Re: Case Model L #302894 in reply to Karen Nelson, 05-05-2004 09:54:06
1935 CASE MODEL L;CLOSEST DATA I CAN FIND IS A 1941 CASE LA, 4 CYL, 403CID GAS, XMSN 4F-1R, 62 HP PTO, 7621 LBS. LO 1010, MID 1840,HI 2170. THE LA MUST HAVE BEEN A BEAST COMPARED TO YOUR L.
Russ
05-07-2004 16:47:02
 Re: Re: Case Model L #302894 in reply to Russ, 05-06-2004 17:52:32
Case Model L; First manufactured in 1929 until 1939 when it was replaced by the Model LA which sported a 62HP(403CID) 6.6 litre engine and it was made until 1955.
Robert Pence
05-05-2004 14:39:08
1935 L could have had rubber tires as original equipment. If the wheels have spokes with rims welded on, the tractor was converted. If the wheels are solid cast iron with rims bolted or riveted on, they are probably factory original.
Dr Cy Kosis
05-05-2004 11:54:29
That would be a 1935 model and the 294th tractor of the L series built that year.
Six digit Case serials use the first and fourth digits together minus 3 to identify the year af manufacture.
302894 3xx8xx = 38 - 3 = 1935
The rest of the digits are the production number for the L series it was that year.
302894 x02x94 = 294
dctom
05-05-2004 18:14:57
 Re: Re: Case Model L #302894 in reply to Dr Cy Kosis, 05-05-2004 11:54:29
DR CY: I DONT THINK YOUR THEROY HOLDS TRUE, CASE TRACTORS WERE CONSECTIVELY NUMBERED, THERE COULD BE CC'S AND C'S AND EVEN LI'S IN THOES NUMBERS I DONT HAVE CARDS FOR SIX DIGIT TRACTORS BUT ALL SEVEN DIGIT TRACTORS WERE NUMBERED THAT WAY DC TOM
Dr Cy Kosis
05-05-2004 19:14:30
 Re: Re: Re: Case Model L #302894 in reply to dctom, 05-05-2004 18:14:57
Yes... Thats exactly what I said..... Series, not model.
L series included LIs and C series included CCs, CCSs, CHs, COs, CIs...etc. The various models are still basically a C or an L.
