Water Pump Question
steve
05-04-2004 19:18:11
Does anyone know how I can Check my water pump on My case 300. I have the engine head off and the radiator off for repair and I would like to know if the water pump works before I put everything back together. The water pump is still attached to the engine block with all the hoses off of it. Thanks
Roger (Mi)
05-06-2004 04:35:09
 Re: Water Pump Question in reply to steve, 05-04-2004 19:18:11
About the only things that go wrong with water pumps are seals and bearings. Although, I had to replace a water pump on a Case 990 because its PLASTIC impeller broke. The Case 300 will not have a plastic impeller. If it turns smoothly, the bearing is likely good. If it doesn't leak, the seal is good. You're good to go!
steve
05-06-2004 18:21:20
 Re: Re: Water Pump Question in reply to Roger (Mi), 05-06-2004 04:35:09
Thanks for the reply roger, I just didnt want to put my engine back together then discover that the water pump does not work. I am replacing a blown head gasket and thought that might have caused the overheating. thanks again. Steve(FL)
