What would this engine on ebay fit into?
Troy
05-02-2004 19:24:08
third party image
what tractore does this fit into?
CP
05-02-2004 20:42:03
 Re: What would this engine on ebay fit into? in reply to Troy, 05-02-2004 19:24:08
660 combine
Troy
05-02-2004 23:26:23
 Re: Re: What would this engine on ebay fit into? in reply to CP, 05-02-2004 20:42:03
Is that all?
mike
05-03-2004 18:07:02
 Re: Re: Re: What would this engine on ebay fit int in reply to Troy, 05-02-2004 23:26:23
you can work it into a 300b,400b,430,530,600b .If you want to have some fun you can put in a Vac.
Russ
05-05-2004 18:03:02
 Re: Re: Re: Re: What would this engine on ebay fit in reply to mike, 05-03-2004 18:07:02
Case engines;
VAC 127CID GAS 15HP
300B 157CID DSL 32HP
400B 148CID GAS 37HP
430 188CID DSL 34HP
530 188CID DSL 41.2HP
600B 165CID GAS 44.6
IF YOU GRAB THAT EBAY CASE ENGINE YOU MAY WANT
TO LOOK AT THE ABOVE INFO TO DECIDE WHAT YOU MIGHT CRAM IT INTO. AT FIRST GLANCE THE LEAST WORK MIGHT BE A RETROFIT INTO A CASE 400B IF ONE IS OBTAINABLE. REMEMBER THE EASIEST THING TO DO MOST OFTEN IS NOTHING. GOOD LUCK.
Jerry W
05-04-2004 19:18:30
How much bigger is this motor than a VAC in both cubic inch and hp?
Jerry W
