case 441 front end loader hydraulic connections
chris spiek
05-02-2004 08:21:22
I recently purchased a case 441 with Draft-o-matic. It came with a Ford front end loader that has never been attached. Mu problem is how to connect the hydraulics. The tractor appears to be set up to acept a loader. Two lines are lines are run from the loader control levers on the tractor to a connection plate at the rear of the tractor. However there are three hydraulic lines coming from the loader itself with only the two connection points on the tractor. There are two seperate lines on the loader that connect to the upper and lower bucket hydraulics. There is also one line on each lift arm that connect together in a T fitting forming a single line with a connector at the end. How do I connect the hydraulics? Any information or a diagram would be helpful.
Terrance
05-03-2004 21:03:31
 Re: case 441 front end loader hydraulic connection in reply to chris spiek, 05-02-2004 08:21:22
Chris,
You need to install a 3 port deversion valve or selector valve in the line that runs from the hitch control back to the 3pt hitch, in one position it lifts/lowers the loader arms in the other position it raises/lowers the 3pth. They are fairly cheap, you can find then at:
WWW.surpluscenter.com hope this helps
Terrance
