Parts for 300 avaliable?
Bob
05-01-2004 19:20:49
I am looking at a 300 (311). While all is in good shape today, what is the parts situation out there? Do Case/IH dealers still carry any? Reproductions? Used parts?
Is there a well known "bad" area of this tractor I need to look more closely at?
Any advise would be great.
C. Amick
05-03-2004 09:36:36
 Re: Parts for 300 avaliable? in reply to Bob, 05-01-2004 19:20:49
Brakes can sometimes be a maintenace problem, but they are easy to repair. Make sure someone didn't let the oil get low in the triple range (if equipped) and mess it up. Sheet metal parts (grill and side panels)are available as reproduction. Engine parts are available from dealers or other suppliers. The instrument panel is not availabe anywhere, as far as I know. Some of the Eagle hitch parts may also be a little hard to find.
Bob
05-03-2004 19:27:54
 Re: Re: Parts for 300 avaliable? in reply to C. Amick, 05-03-2004 09:36:36
How do I tell if the oil in the triple range (is has one) ever got to low and messed up? Can I tell simply by driving through all the gears?
The eagle hitch is all there, with top link.
This is the type of info I was looking for. THANKS alot!!!
Bob
C. Amick
05-04-2004 06:04:35
 Re: Re: Re: Parts for 300 avaliable? in reply to Bob, 05-03-2004 19:27:54
If you have a triple range unit, there should be a shift lever on the right side of the transmission in just in front of the main gear shift. It should have High, Low and Direct drive. I would suggest you run it through the gears and listen for gear noise. There is a plug with a dipstick on it for the triple range unit. Mine was dry when I bought it. It is also the reservoir for the hydraulic oil. So, if you have a hydraulic leak it depleats the oil.
Chuck
05-02-2004 06:40:31
Hi Bob, we just bought the fenders for 318 here
Link
Chuck
george md
05-01-2004 22:08:34
Bob,
I bought one in 1959 with 90 hours on it, since then we wore out the engine and rebuilt twice . Most of the rest of the tractor is original , has had 1 set of rear rims and several sets of rear tires . It is a utility with the ag attachments, still runs and handles great.
george
Mike M
05-11-2004 09:57:10
 Re: Re: Parts for 300 avaliable? in reply to george md, 05-01-2004 22:08:34
I also have a 300 (and a 350) also that I got from my father in law who farmed with them for years. I seem to be able to get many parts from local Case dealer. Just had to get a water pump. If you find a good web site for parts I would like to know. Mike
