I need any info on Case plows.
Kory Kroeger
07-19-1999 18:51:51
If anyone has information on case plows, i need it!
I've found a two bottom, but was told it mounts on the axle. It was on a VAC.
Any information on if this is true, and any place I could find a Case two bottom pull-type in Northwest Iowa would be much appreciated.
Thank you!
Jerrie Lott
07-19-1999 19:42:29
 Re: I need any info on Case plows. in reply to Kory Kroeger, 07-19-1999 18:51:51
I have a two bottom for my VAC and it sure don't mount on the axle, it mounts on the Eagle hitch. It is about all I want to pull. I would hate to try and pull it clay, we have good black dirt where I live. I was told that they made a two bottom in 12" I don't know it would be better than this 14". I think that they also made a mounted one bottom 16" If you are going to pull it with a VAC I don't think you want a pull type, if you get in a tough spot you will never get out of the ground, remember you only have 20 hp
