vac pto coupler appears too long??
Dave
04-30-2004 07:04:35
I have a vac 1946,it came with no pto assembly other than the housing.I found one listed on ebay it came complete and looks good "no missing teeth ect".However when I attempted to install it I found that it will not go all the way in.The shaft?coupler appears to be about an inch to long.am I missing somthing here? Were they made in different lenghts?should I cut the coupler? Help much appreciated.
MHF
04-30-2004 19:50:57
 Re: vac pto coupler appears too long?? in reply to Dave, 04-30-2004 07:04:35
All should be same you might make sure internal shaft is all the way in. Hope this helps and good luck.
