DB 995 diesel flooding- Possible?
jimtex
04-30-2004 05:55:34
Yesterday I was brushhogging some wooded area when some tree limbs must of hit the fuel injector. the engine reved up. I back up and turned the engine off. I thought it was out of diesel. I saw that it was not when I put 5 gal in the tank. The throttle lever on the fuel injector spring was stuck wide open. Now the engine will not start. Any suggestions?
Elmer
04-30-2004 17:44:24
 Re: DB 995 diesel flooding- Possible? in reply to jimtex, 04-30-2004 05:55:34
Is there a chance the shut off linkage was pushed off the lever at the pump itself.
jimtex
05-01-2004 05:38:48
 Re: Re: DB 995 diesel flooding- Possible? in reply to Elmer, 04-30-2004 17:44:24
No its attached. I bled the secondary filter and some air came out. Still didn't start. Started to rain hard and had to quit. Will keep trying.
joe e-tx
05-01-2004 06:23:17
 Re: Re: Re: DB 995 diesel flooding- Possible? in reply to jimtex, 05-01-2004 05:38:48
jim try this ,cav pumps cams hang at times,have someone try to start tractor and move throttle lever open closed while you tap on inj. pump at end with inj lines come out. (tap not HIT).this happened to me on my massy and my ford, both have same type of pump as my 995/6 db.let me know if this helps ,im near tyler.
joe
