case drill
mm
04-29-2004 09:53:05
I own a case grain drill and do not have the owner manuel. The problem is the unit will not lift. I can manuelly move the drill and the disks down and engage the clutch. when I pull the handle for the clutch the unit does not lift nor does the main drive gear (which connects to the clutch) move either. Is there a shear pin in the gear on the main shaft. Any ideas would help at this time
