580 CK sluggish shuttle shift transmission
gwinnibarge
04-29-2004 07:39:48
This following method to deal with a sluggish shuttle shift was posted elsewhere. Has anyone used it and can you tell me if it will work? Any reason to avoid this method?
Thanks
Resolution:
1. Drained the oil (run a bit to get it ALL)
2. Filled with ~ 5 gal of diesel fuel
3. Ran for 15 minutes, flushed out diesel
- this removed the water causing the foaming,
normal oil change would not remove the water
4. Filled with 30wt non-detergent diesel
"motor oil" from Tractors-R-Us (black can)
5. It now takes two or three minutes to warm up,
then will work HARD "all day".
I suspect that it had the same old problems
that my Clark Michigan loaders had - just
getting old & needs a bit more viscosity ...
My problems solved , no foaming & has all the
power one could want :-)
gwinnibarge
04-29-2004 08:07:28
 Re: 580 CK sluggish shuttle shift transmission in reply to gwinnibarge, 04-29-2004 07:39:48
Nevermind. I came across the answer to my question. The "preferred" method is here>Link
>Link
