52 VAC side gear
Richard Shackel
04-28-2004 18:02:38
Does anyone out there know if i have to take the tranny apart to replace a right side,side gear????thanx...Richard
mj
04-28-2004 23:13:19
 Re: 52 VAC side gear in reply to Richard Shackelford, 04-28-2004 18:02:38
The manual says you have to unbuckle the rear axle housing from the back of the transmission so you can get the side gear out from the front. Pull the PTO housing first and take a look since you've got to have it off to use the 'nut and 1/2" of washers' trick to push the axle out of the bearing anyway.
Richard Shackelford
04-30-2004 07:58:47
 Re: Re: 52 VAC side gear in reply to mj, 04-28-2004 23:13:19
Mj
thanx,Joe(wa)sent me some info to.Seems i might be able to pull the right axle and seal and some other things out of there to get it out,without tearing the rearend from the tranny.I believe i have take the pto off to...Richard
mj
04-30-2004 08:23:16
 Re: Re: Re: 52 VAC side gear in reply to Richard Shackelford, 04-30-2004 07:58:47
Yeah...looks like there might be room enough with the PTO removed to get the side gear out from the rear....sure save some time!
Richard Shackelford
04-30-2004 19:30:21
 Re: Re: Re: Re: 52 VAC side gear in reply to mj, 04-30-2004 08:23:16
Never done it,I guess i have all day.(no other choice)...Thanx
