David Brown 1210 Hydraulic
mike
04-28-2004 15:19:26
I have a DB1210 with an auxilliary hydraulic pump being run off the pto, and a large multiple gallon hydraulic resevoir behind the seat. When hot and been working under load, if I shut down and then release/lower the bucket quickly, the returning fluid blows the top of the resevoir right off. It also seems to pump by steering servo and up the shaft as well when hot. Any ideas what this is and possible remedies?
Elmer
04-30-2004 17:46:36
 Re: David Brown 1210 Hydraulic in reply to mike, 04-28-2004 15:19:26
When you shut off the engine and lower the bucket or loader the fluid id not being pumped into the opposite side of the cylinder which will in turn raise the reservoir level. The steering hand pump has to be resealed or replaced.
