clutch problems w/ Case-o-matic tractor
Ryan Thompson
04-27-2004 20:59:10
I have a Case-o-matic 600 something, or so I was told when I bought it. I think it is around a 1960 model, about 40hp. I was using it last fall to move some dirt, nothing big, when the clutch went out. The tractor still runs well, just no clutch. I can start it in gear with a full battery charge, and while moving up hill it will stop. But not moving down hill or on the level. I have been told locally that it may be some kind of hydrolic or tork converter type clutch. And if so very expensive to fix. Dose any one know about the Case-o-matics? Or has any one had this problem? Any info appriciated, thanks Ryan
Dale Roisum
05-02-2004 01:52:09
 Re: clutch problems w/ Case-o-matic tractor in reply to Ryan Thompson, 04-27-2004 20:59:10
Ryan,
The Case-O-Matic drive uses a torqu converter similar to the ones in a car with automatic transmission. The leaver on the right of the steering wheel engages the torque converter lock-up clutch (a single disc in the front of the converter) giving direct drive. The converter also contains a second multi-disc clutch pack behind the converter that connects the torque converter to the drive shaft going into the transmission. This is the clutch that operates when you push in the clutch pedal. Both clutches are hydraulicaly operated which means they use hydraulic pressure in a drum to apply pressure to the clutch plates instead of the springs in a conventional pressure plate clutch. The hydraulic pump that operates the drive system is a separate pump than the one for the 3 point and hydraulics. They are both located in the front most section (torque tube) and use the same fluid. Problems can result if the pump is weak, or the torque converter is worn and won't hold pressure, or the valve body is leaking or out of adjustment, or if the clutch discs are worn or warped from overheating, or if the torque converter fluid filter is very dirty, or if the oil level in the torque tube is very low.
The Case service manual gives fairly easy test procedures to check pressures at various locations on the system to identify where the problem exhists. These tests are the best way to diagnose your problem other than checking the levels and filter. Incidently the filter in front of the radiater is the one for the case-o-matic and the one on the right hand side of the hydraulic pump housing (under the gas tank) is for the 3 point lift and auxiliary hydraulics.
e-mail me if you need any help. I am very familiar with the 600 case-o-matic and I have gone through mine completely. Good luck, Dale
lincoln
04-30-2004 09:39:54
Sounds exactly like what happens when you get low on hydrualic fluid. Does the tranny work when you engage the direct drive?
Ryan Thompson
04-30-2004 19:28:57
 Re: Re: clutch problems w/ Case-o-matic tractor in reply to lincoln, 04-30-2004 09:39:54
Lincoln, I'm not sure I understand all about the automatic functions. There is a lever to the right of the steering wheel that seems to operate a higher range. Before the clutch problems started I could pull the lever back toward me and it would go into a higher range, push the clutch in and it would return to the other range. Now this function does't work either. Is this the direct drive you are talking about? Another question, does the clutch operate with the same hydrolic fluid as the lift? The fluid for the lift seems to be fine, and the lift operates good too. Thanks for your interest, Ryan
John Saeli
04-28-2004 04:48:42
Hey Ryan: You could rebuild it reasonably if you do the work yourself. Some simple things to check are fluid level and filter condition.
