300 case
LEWIS
04-27-2004 06:00:36
I'm having problems with this tractor, tractor was not charging so i replaced gen. and regulator, charging great now, but when the tractor is not running it has a short in charging system, i disconnect the armature wire at the gen. it goes away or the batt. wire at regulator it goes away. had gen. and reg. tested and both are ok. what else could be wrong, does anyone have a wiring diagram for this tractor?
please help?
C. Amick
04-27-2004 13:51:24
 Re: 300 case in reply to LEWIS, 04-27-2004 06:00:36
Does the ammeter show "discharge" when the tractor is off? If so, pull the cover off the voltage regulator and make sure the points aren't sticking.
Chuck
04-27-2004 12:22:08
Lewis, I just tried to take a photo of the wiring Diagram from my Case Manual, Will e-mail if you would like . Chuck Caddy
