DC-4 Geared Too Fast
Gene Dotson
04-26-2004 19:49:32
I have a 1951 DC-4 with a heavy duty Roust-a-Bout loader. The gearing is way too fast to make this a good loader tractor. I would like to change the sprockets to slow it down. Does anyone know what would be the sprocket part numbers and tooth count for a slower ratio? My DC-3 is geared much slower, maybe I could trade the sprockets with it... Gene
Gene Dotson
04-27-2004 18:39:00
 Re: DC-4 Geared Too Fast in reply to Gene Dotson, 04-26-2004 19:49:32
Thanks for the reply guys. Guess I need to keep a look out for 38 tooth final sprockets. Were there different drive sprockets? The brakes shafts are going to have to come out for new seals anyhow. Might as well make a clean sweep out of it... Gene
dctom
04-27-2004 07:28:50
DC-3 AND DC-4 ARE THE SAME UNLESS SOMEONE HAS PUT 31 TOOTH SPROCKETS IN YOUR DC-4 DCTOM
Glenn FitzGerald
04-26-2004 20:15:49
We've had plenty of DC's in our time; three at the present, and I am not aware of any difference in the gearing from a DC-3 to a DC-4. The DC needed a 5 speed transmission.
ted
04-26-2004 20:35:42
 Re: Re: DC-4 Geared Too Fast in reply to Glenn FitzGerald, 04-26-2004 20:15:49
There were special spokets in the "D" and that might be what you are calling the DC-4, or someone could have changed sprokets in one of the tractors. There were two available that I know of, a 38 tooth and a 31 tooth. I would guess you have one of each. You could switch them around? Or call Don Livingston, Austin, Mn. He might be able to supply you. DC Tom is really the guy to ask.
Gene Dotson
04-27-2004 02:46:43
 Re: Re: Re: DC-4 Geared Too Fast in reply to ted, 04-26-2004 20:35:42
Ted; I have a D, a DC3 and a DC4 and the dufferences are very obvious. This DC-4 runs about 3 1/2 mph in first gear. I suspect it may have the same gearing as used in the D with the smaller tires... Gene
