VAC brake leaks
ELMER
04-26-2004 19:41:49
My 53 VAC brakes have 90 wt dripping out of both housings. What kink of job is it to re-do seals? Are the parts available? Thanks, ELMER
Dug G.
04-27-2004 11:38:04
 Re: VAC brake leaks in reply to ELMER, 04-26-2004 19:41:49
The seals aren't to bad to replace. Best bet is to take your old seals out or get the number out of a parts book, and have NAPA cross reference it over. On mine, I did have a little trouble getting the nut retainer loose enough to get the big nut off. Once you open up the housingyou'll see it s not to bad. I used torch to lightly burn the oil out of the brake linings, and it worked pretty well. good luck.
ELMER
04-28-2004 05:40:41
 Re: Re: VAC brake leaks in reply to Dug G., 04-27-2004 11:38:04
THANKS
mike
04-27-2004 10:54:39
Well, join the club. I just repainted mine and had all the leaks fixed. drove it home and bam, leaky seal. Something else to fix.
