VAC charging
Kent
04-26-2004 11:19:48
Ok you guys (and gals)have been extremely helpful in getting my 51 vac working but this charging thing is really stumping me
i have a rrebuilt generator - 6 volt positive ground system - new voltage regulator and have wired it as ive seen is some of the old posts - field to f on regulator armater to a on regulator ammeter to batt on regulator
when i start it up it pegs out the ammeter and boils the battery
i know these had a switch which performed the reugulation of charge but i would think the regulator would take the place of that
thanks in advance for your help
Jim Cox
04-28-2004 05:52:13
 Re: VAC charging in reply to Kent, 04-26-2004 11:19:48
try pulling the field wire off the generator. then we'll know if it's the genny or the VREG. If charging slows, it's in the VREG or wiring. If it still boils the BATT, it's the genny.
holler back
Jim Cox
Genny Rebuilder Guy in SW Missouri
coxster at yahoo dot com
mj
04-27-2004 19:30:52
third party image
What everyone already said and.....it should look like the diagram.....Roger?
C. Amick
04-27-2004 13:47:48
Another idea I had: Does your generator have the 3rd. adjustable brush in it? If so you might be able to decrease your charging rate some by sliding that brush.
Art
04-27-2004 03:48:43
I'm not sure your supposed to have a voltage regulator, I though it's should be a 6 volt generator cutout switch....Big diffrence....
Klyde
04-26-2004 17:53:08
OK, you must have a regulator, as you say you have a place for the field wire. The only thing I can think of is that one or both of your regulator mounting screws is too long, and has gone through the housing, and is hitting the fields, full-fielding the generator.
C. Amick
04-26-2004 14:53:35
Do you have a true voltage regulator or just a relay switch like the one that was originally on the tractor? Are you still using the light switch with the resistor on it? I think if you now have a real voltage regulator installed, you will have to do away with the resistor. If the generator is equipped with only a relay, you will need the resistor to control the charging rate.
