Simplification to support DC - VAC
Paul f
04-26-2004 05:50:39
Now that I have added a little friend (1950 VAC with trip bucket loader) to play with my DC3 (Live PTO Dual hydraulics), I was wondering if I could simplify my stockage of lubricants...
VAC manual calls for 3 different weights of oil for the hydraulic system (low pressure pump)depending on temperature...I replaced the PTO Clutch plates on the DC and based on that am using Dexron in the PTO/Hydraulic which was a mid 50s change noted in Serivce Manual. I will be using both tractors year round in NE Pennsylvania so temperature range is probably -10 up to 90+
Question can I use the same fluid in both tractors year round??? and would it be: Dexron
Hy-Tran
TCH
Something else???
Please help my shop is going to look like an oil storage facility if I have to add more different fluids to the inventory
Paul f
mj
04-27-2004 19:35:58
 Re: Simplification to support DC - VAC in reply to Paul f, 04-26-2004 05:50:39
I use 20wt in my VA Eagle hitch tractors year around for the same temperature range that you have there. I've seen posts where some are using Hy-Tran but have no info on the Dexron.
