SC-- New Arrival!
Glenn FitzGeral
04-24-2004 18:12:47
Bill Koski, owner of S+K Farm&Yard of Owosso, Michigan just delivered my SC which I bought sight unseen.last December. It is exactly as he described. I am very pleased. First problem I need to solve...When I went to start it for the first time the engine was tight. I took out the plugs-still tight, took out the starter-engine is now loose. The bendix isn't perfect but the ring gear looks like all the teeth are about half worn off. It looks like I'll be splitting the tractor, but what would you say is causing the starter/ring gear to jam up? The battery is dead. Too dead to even engage the starter. I expect a new ring gear and bendix will solve my problem, but have any of you folks had this experience? Thanks, Glenn F.
C. Amick
04-26-2004 09:19:12
 Re: SC-- New Arrival! in reply to Glenn FitzGerald, 04-24-2004 18:12:47
You may want to get a new bendix for the starter, but before I split the tractor I would try a little experiment. Try changing the mounting position of the starter by rotating it and locking the set screw against the housing to see if it will work in other positions. If you find a position it will work in, drill another set screw hole in the starter housing to keep it in that position. You might be able to get a few more years out of it, if the ring gear isn't too worn.
ted
04-24-2004 23:52:32
Glenn, this wasn't with an SC but I heard of a ring gear being worn enough to allow the bendix to partially engage but because the teeth on the ring gear were worn it actually allowed the teeth to mesh on top of one another and wedged the bendix. It actually started to push out on the starter drive, producing a pressure that hindered the engine from turning over. Make any sense?
