Rubber in DC pulley
Will
04-24-2004 17:17:41
Anyone tried to replace the rubber pins in a DC pulley with steel pins? Any other ideas?
Paul f
04-25-2004 06:53:58
 Re: Rubber in DC pulley in reply to Will, 04-24-2004 17:17:41
Will: Glenn is correct the rubber pins are to reduce shock to the parts... You can't get the pins from Case anymore. I got neoprene rope from Mc Master-Carr for a couple of bucks and cut it to short lengths... I have some left if you want any. Getting them in is not easy. I took the pulley off and left it off some time ago (makes shifting easier) don't have to pull back so hard on clutch lever to stop the gears.
IGlenn FitzGerald
04-24-2004 18:17:20
I had my pulley off for a year or so but decided to put it back on. I re-used my rubber pins. Why are you considering steel pins? I would think the rubber pins are intended to be a sort of shock obsorber producing less jar on the engine, etc. particularly then the pulley is under load. My theory. Glenn F.
Joe
04-26-2004 06:12:38
 Re: Re: Rubber in DC pulley in reply to IGlenn FitzGerald, 04-24-2004 18:17:20
Why do you need a shock absorber in the pulley? A 50 - 100 ft. belt provides that. Earlier D worked fine without the rubber pins.
