Richard, If you run the tractor engine with the torque tube empty the hydraulic pump will eventually run dry and ruin it. If you have no significant external hydraulic leaks the torque tube oil has leaked into the transmission. Check the oil level in the transmission. The drive shaft is probably shot. The reason the oil leaks out of the rock shaft housing is because the piston seal (leather cup or o-rings depending on your type piston) is leaking. The oil that leaks pass the piston seal collects in the rock shaft housing and normally drains back to the torque tube via the rock shaft vent/leak-off tube. If the tube is plugged or overcome by major leak-by, the oil in the rock shaft is force out externally via the zerks, gasket, rather than returning to the torque tube. When you raise the hitch the oil pressure on top of the piston can be as high as 900 psi. If the cavity (rock shaft housing) under the piston has more leak-by oil than can drain back to the torque tube very quickly, the pressure under the piston in the rock shaft housing rises to the point that oil leaks externally in the path of least resistance. Joe
