SC engine blow-by
John McMillian
04-24-2004 05:54:04
My 1951 SC has a vent tube out the top of the valve cover, apparently for venting the engine crankcase. When running there is a small amount of blue smoke blowing out, not a lot. Is this normal or an indication an overhaul is due?
C. Amick
04-26-2004 09:28:39
 Re: SC engine blow-by in reply to John McMillian, 04-24-2004 05:54:04
Mine has blow-by under a hard pull, but it is not blue. Have you had the valve cover off? Could it be gunked up enough that the oil is not draining back down into the block fast enough and it's holding too much oil in the head which gets into the cylinders around the valve stems?
roger
04-24-2004 19:58:37
or rings, anything that goes past the piston rings will come out that vent also, don't be too concerned however, just watch the oil consumption, if it starts using alot then think about an overhaul, however you can buy a lot of oil for $2000.00
Dave
04-24-2004 05:58:01
John,
You may have some blowby on the valves. Both of mine don't blow any smoke out the breather.
Dave
