SC transmission oil
John McMillian
04-24-2004 05:50:40
My SC manual says that the trasmission should hold 10 3/4 gallons of gear oil. When I drained it to replace a seal, I only got 5 gallons. It looks like the area for the PTO gear is a seperate compartment. Is this quantity included in the 10 3/4 gallon amount? Or was the transmission just very low on oil?
C. Amick
04-26-2004 09:49:27
 Re: SC transmission oil in reply to John McMillian, 04-24-2004 05:50:40
There is no separate compartment for gear oil. There is a hydraulic oil compartment at the PTO for tractors equipped with the hydraulic lifting bail. I think it holds around 2 gallons.
John McMillian
04-27-2004 05:31:18
 Re: Re: SC transmission oil in reply to C. Amick, 04-26-2004 09:49:27
What fluid should I use in the PTO compartment?
C. Amick
04-27-2004 06:47:57
 Re: Re: Re: SC transmission oil in reply to John McMillian, 04-27-2004 05:31:18
I just use cheap hydraulic oil in the reservoir for the hydraulic lifting bail. No special type of oil.
Dave
04-24-2004 05:56:39
John,
You were just very LOW on oil. I drained mine and got the correct amount.
replace the seal and filler up, no hidden compartments.
Dave
