Case VAI Hydraulics
jhill
04-23-2004 10:54:02
I am working on a Case VAI for a friend and I really don't know anything about this model tractor. The hydraulics are not working. He said they were working one year and over the summer they quit. while sitting. It has an engine mounted pump and a control lever mounted near the steeering column. Any one have any ideas where to start. what type of pump is this? Thanks for any help.
jhill
mj
04-23-2004 20:47:51
 Re: Case VAI Hydraulics in reply to jhill, 04-23-2004 10:54:02
Just finished researching some old Case info....try this: clean around the pump fittings to keep dirt out and remove the two lines, fill the two pump ports with motor oil and reconnect the lines, start engine and operate hydraulics. This should get the system primed for you.
Dave (WA)
04-23-2004 18:47:31
this motor showing the hyd, pump will this pump fit in a 148 motor for a case 300 series?
mj
04-23-2004 20:54:47
 Re: Re: Case VAI Hydraulics in reply to Dave (WA), 04-23-2004 18:47:31
I have not a clue..... I understand that the 300 engine was basically an up-sized VA Series engine but beyond that????
Joe (Wa)
04-23-2004 23:10:36
 Re: Re: Re: Case VAI Hydraulics in reply to mj, 04-23-2004 20:54:47
Cam gears are both 48 tooth but part numbers are different. Maybe one gear is just wider than the other. I haven't checked the p/n's on the crank gear or blocks yet, maybe tomorrow. Worth taking a look at considering the lack of used steering pumps for the 300's.
mj
04-23-2004 13:49:09
third party image
Check the oil level in the torque tube, should be level to plug hole, and check tightness of pump intake line (larger of two, closest to engine) at the pump and the torque tube to be certain it's not sucking air. It could also be that the relief valve in the control valve is stuck open or the pump is not turning (unlikely) due to a problem with the drive gears in the timing case or. .....You should really get a service manual before you get in over your head and avoid doing something really bad due to lack of information..... .such as: running the engine for an extended period of time with the pump dry (it's NOT self-lubricating) and destroying an otherwise good component.....Roger?
