Case 430 controls
Illini Case
04-22-2004 17:21:06
I have 2 430's. One is diesel and it's 3pt. control consists of 1 lever to slide up and down. My gas 430 has that same lever but also has 2 other levers that go up and down. Seems that the 2 additional levers raise and lower the arms but only temporarily as they return to where the main lever had been set to. I am selling the gas 430 would it be to my advantage to swap the controls(Is it an upgrade). Is this change just a matter of swapping the controls and the top part of the hydraulic pump housing (looks like it is tapped for externals).
Roger (Mi)
04-23-2004 04:54:59
 Re: Case 430 controls in reply to Illini Case, 04-22-2004 17:21:06
One control should slide up and down for position control of the three point arms. The other two levers should move back and forth to operate hydraulic remotes.
ted
04-22-2004 20:53:03
I have a 400b, but it sounds to me like you have one tractor with remote valves and that you also have a bad "O" ring somewhere. If they are remote valves they should not move the three point arms. There must be a leak somewhere. As to their value? I guess I'd want them but I can't tell you how much trouble you'll have in the switch.
