Need a fan blade?
Fred
04-22-2004 13:13:18
There's one on eBay for a VAO
JT
04-22-2004 22:27:51
 Re: Need a fan blade? in reply to Fred, 04-22-2004 13:13:18
When it comes to fan blades when a new one is available I would walk past the used one with a ten and a half foot pole and run away VERY FAST.
I have lost two tractor rads so far and from now on fan blades get crack checked when the rad is off and time permits.
JM2CW
JT
Jason
04-23-2004 08:43:57
 Re: Re: Need a fan blade? in reply to JT, 04-22-2004 22:27:51
You must have had the worst luck of anybody in the world to have lost two radiators. You are one up on me if you can find a new fan blade for a VA series tractor. I haven't been able to locate one so I got a used one ($20.00), cleaned, checked, painted, and installed it. Even if I had to weld and balance it, it would be much more reasonable than new, if I could find one. Had one guy quote me $120.00 to fabricate me one using my old one as a pattern.
