Loss of hydraulic on a 2390
Anthony Sloan
04-21-2004 08:02:55
I was talking to a gentleman about a 2390 which loses hydraulics when he turns the wheels to short or sometimes (I believe) when he shifts. He said the problem goes away if you shut off and restarts the tractor. Anyone got ideas, another gentleman told me he had a similar problem on a 2290 but his steering was unaffected; it involved cleaning some valves on the side of the tractor. I know nothing about Case tractors, anyone have ideas?
Shane
04-23-2004 07:05:05
 Re: Loss of hydraulic on a 2390 in reply to Anthony Sloan, 04-21-2004 08:02:55
We had a 1070 do this exact thing. It ended up being both a weak hydraulic pump and the steering valve body was sticking.
RAY
04-21-2004 19:52:40
sounds as if your sucksion screen on hydraulic pump is plugged. pull rear plate and pto to get at it.
mEl
04-21-2004 18:57:07
If the rps 34 trans stops driving when the wheels are cramped it indicates to me that the steering pump is marginal. Flow from the steering circuit goes back to the rps valve and feeds the reverse lockout spool after regulation. If the flow stops during steering, the reverse lockout spool loses its supply. If the reverse lockout spool is out of position, flow to the proper clutches is affected. Get a trained tech in your area to flow test the 8 Gallon steering pump.mEl
Mel
04-22-2004 12:50:51
 Re: Re: Loss of hydraulic on a 2390 in reply to mEl, 04-21-2004 18:57:07
don't look for the suction screen in the rear on a 23 it is in the mid tractor area. Mel
