case axle rebuild or replace ?
chopper
04-20-2004 20:27:20
The key way on my axle is shot, I can fill it in with weld and grind in a new key way but not sure if this would make axle brittle, or should I replace ?????
roger
04-21-2004 20:59:57
 Re: case axle rebuild or replace ? in reply to chopper, 04-20-2004 20:27:20
I would weld it,
a decent arc welder or wire feed will fill in quick with out getting the spindle too hot,
and if you are like me and have more time than money what do you have to loose ?
even in the worst case and it breaks you most likely are not on the road anyway,
good luck
chopper`
04-21-2004 16:11:17
the axle is from a 1953 case vac,
Jim M
04-21-2004 09:36:42
I welded mine up on my 351 and use it at tractor pulls and is doing fine so far
DKase
04-21-2004 07:10:27
It is hard to answer your question without knowing what you are working on.
Don L. @ Austin Mn
04-21-2004 07:28:54
 Re: Re: case axle rebuild or replace ? in reply to DKase, 04-21-2004 07:10:27
Yes , will need to know what tractor. I bet $$ it a 611B, or 511B or a 350. Welding axles is not a thing to do. Putting a new key way on the same axle is. Make me think of the 7 man hrs to get out 900 Case alxles, only to have the guy back out.
