Case 540 engine help!!!!!!!
Phillip
04-20-2004 16:42:08
I have a 1960 Case 540 with the 159 gas. It got water in it via the rusted off muffler and the front liner is cracked. Where is a good place to buy an engine kit? I have found a completely rebuilt 188 Diesel for it. What is would I need to put it in? He has the gas tank, the starter and flywheel are on it. Is the radiator and air cleaner different? Is the 188 a good engine? Thanks for any help. Wanna buy the tractor?
Dennis/Ohio
04-25-2004 03:48:38
 Re: Case 540 engine help!!!!!!! in reply to Phillip, 04-20-2004 16:42:08
Hi, I've not swapped before but from previous posts the 188 is about 2 inches longer than the 159. I think the gas tank is where they make up the 2 inches in the sheet metal? My 540 has a loader frame that wraps around the front. I still don't see how the extra 2 inches would fit in the loader frame.
Best wishes, Dennis.....
George S. in the real NY
04-24-2004 04:40:16
In summer '00, I bought sleeves and gaskets for my 159 from the Case dealer. I used viton orings I got thru McMasterCarr. If memory is ok, I think there are 2 possible designs of sleeves, something about the ledge/step at the top. If you need info, get back to me and I can look in the parts book. I think the sleeves were stocked in the Philadelphia warehouse and were not old stuff from the 60's. Try a dealer, especially one that used to be a Case dealer. I considered the swap to diesel, but for accaisional use on a small farm, stayed with gas. George S.
Roger (Mi)
04-23-2004 05:19:14
There are plenty of after-market kits available for the 159 gas. (Central Tractor) To change to diesel, you'll need a fuel return on the fuel tank, different fuel lines, different oil guage, a larger battery, linkage for motor speed, fuel shut-off control (looks like a choke knob). That's about it.
