VAC Oil Pressure
Kent
04-20-2004 10:14:26
My tractor (51 vac) runs great, but doesnt seem to register much (7 lb) oil pressure. the gauge is new (reproduction case) as is the line (plastic 1/8 th line) - I dont want to do any damage - what should the pressure read - is this a sign that my oil pump is bad?
frdmnn
04-20-2004 18:13:50
 Re: VAC Oil Pressure in reply to Kent, 04-20-2004 10:14:26
make sure you bleed the air out of that little plastic line.
start engine , crack open the line on back of the guage till you get a good stream of oil . i bet it reads different afterwards
Russ
04-20-2004 17:09:16
VAC Oil Press.; Is the oil pan unmucked and clean?
Is the pick up/oil siphon clear and clean and not restricting oil delivery to the oil pump?
Is the pressure regulating spring of the proper length?
C. Amick
04-20-2004 13:59:32
The tube that slides up into your oil filter isn't missing is it. At that pressure, you may not be getting proper lubrication to the head. If you pull the oil pan to check the oil pump, shake some of the rods to see if any of the rod bearings are badly worn.
mj
04-20-2004 13:03:58
third party image
What Joe(WA) said and: After 50 or so years the relief valve spring in the oil pump will lose a bit of its' resilience, this will lower your oil pressure...all by itself. Drop the oil pan and remove the retainer and spring from the pump housing; the spring should have a free length of 1 and 15/16 inches (see photo). Just stretch it until the free length is 2 inches and put it back together; the little bit of extra length will help compensate for internal wear of engine. You can also use washers between the retainer and the spring to shim the valve to a higher pressure. Like Joe aid, you're shooting for 15-20 psi so don't go overboard here....more is not always best when you go beyond design parameters...leaks, bearing erosion, etc..... Roger? For more info go to link .....click to enlarge.
Joe (Wa)
04-20-2004 10:49:14
Design oil pressure 12-20 psi @ operating temp and PTO rpm.
Check oil press with 0-30 psi gauge.
Many reasons for low oil pressure, not often oil pump but sometimes oil pump relief.
May be a combination of worn bearings, oil filter inlet stem tube missing, oil pump suction strainer partially blocked with sludge, etc.
Run the engine with valve cover off, check for some lubrication to valve running gear and run off down through pushrod tubes for cam bearing lube.
Joe
