VAC PTO
Ron in mid MO
04-20-2004 03:47:51
My 1950 Vac is in need of a pto unit. Will all of the pto part interchange (lever, gears and bearings)? Most of my unit was missing when I got it. Just the pto shaft, rod control and lever assemble-shaft all I have. Thanks
Jim Yadon
04-20-2004 10:56:40
 Re: VAC PTO in reply to Ron in mid MO, 04-20-2004 03:47:51
Just wanted to add my two cents worth in. I restore vas tractors and they have a different casting number than the standard vac. The vas unit is deeper than the standard vac pto unit.
Since it is a deeper pto the main power shaft will not seat correctly into pilot bearing there about 3/4 difference in depth. I have tried this before but vice versa. When I tried the vac pto on the vas the the main power shaft stuck out farther than the pto would allowed to go in. The holes lined up but that was just about it. Hope fully this will help.
Jim Yadon
Augie
04-20-2004 09:27:28
I should have at least one good one if you need the whole thing. I'm in Columbia so getting it wouldn't be too much trouble for you.
mike
04-20-2004 03:52:32
Most of the others will interchage in the Vac series. If your planning to do some heavy work look for one out of a Vas.(heavier gears)
