Case valve seals
David Fuller
04-19-2004 21:04:51
I am currently restoring a 1951 Case DC-3, and she leaks valve oil into the cylinders BAD. I had heard about a type of 'valve umbrella' that slips over the raised portions of the cylinder head, and seals around the valve stem. The person had told me that when he ordered them, he had to order it for an old Chevrolet V8, that I'd assume used about the same size valvestems. I would like to know where these parts are available, so that I no longer have oily cinders coming from my exhaust. Any help would be greatly appreciated.
george md
04-19-2004 21:44:55
 Re: Case valve seals in reply to David Fuller, 04-19-2004 21:04:51
David, If that old gal is leaking that much oil down the valve guide , it doesn't need seals it needs guides . Good guides and a good valve grind will make it start much better also. The only other thing that would make it use that much oil down the guide would be sludge build up in the head causing it to flood the guides. george
