Case 311b 1957 info
jpbm1976
04-19-2004 13:09:51
Hi all, Just bought this tractor and love it. Need help locating some parts. The front end grill/screen on the right side. Also missing some 3 point hitch parts (eagle hitch).The gauge cluster is broke, and that dosent look cheap.
I was also wondering if you can adjust the brakes?
Any help will appreciated. thanks, Jake
mike's600
04-19-2004 18:11:17
 Re: Case 311b 1957 info in reply to jpbm1976, 04-19-2004 13:09:51
I can help you on the 3pt hitch stuff, i'am parting my311b down. The sreens are alittle hard to come by, i'am using the ones i have on my 600b Com.The guage cluster can be rebuilt with the right guages(expensive) finding a used one is hard also, keep an eye on ebay. Last one brought over 200.00. I fixed a metal panel shaped like the cluster and installed case repo guages.
The brakes can be ajusted where the rod conects to the brake pedal.Your disk are glazed so ajusting may not work. Sometimes you can rough them up with sand paper , i did all of this first and still ended up replacing the disk
